What The Flex can the LG G Flex2 do?
Ohayo!
if only it has removable battery then you can easily swap it out but there is fast charging.
"LG G Flex 2 comes with a fixed 3,000mAh battery lurking behind its battery door. You can see it screwed in there, but unlike the G3's it's not designed to be user-replaceable. On paper a 3,000mAh cell sounds like enough for a high-end smartphone. But in practice we've found the phone's battery life to be average at best, and under certain circumstances it's possible to drain the phone to dead alarmingly quickly.
With mixed use across Wifi and LTE, consisting of web browsing, messaging and social app usage, with a little music playback from Google Play Music's offline cache, we typically got around 12 hours between charges from the G Flex 2, with around three hours of screen-on time.
With no wireless charging or battery-swapping options, LG's relying on faster charging to bring a flagging G Flex 2 back to life. The manufacturer quotes a figure of 50 percent in 40 minutes, which about lines up with what we're seeing using the bundled charger"
the charger how many A?
i normally buy 3rd party with at least 2A to charge cause the one come bundled always 1.5A or lower
Gaiason
Anybody knows what would happen if there are 2 ppl taking a selfie together ?
Would LG G Flex 2 take a photo if any one of them says the magic words or do the gestures?
Weird qn.. If close enuff and can capture the commands.. Then is yes bah.. :(:(
mosmos
High Honorary Member
LG got a new phone, should giveaway this one as one of the prizes here also~!
Specs are good at this price~!
http://www.hardwarezone.com.sg/tech...le-lg-aka-smartphones-now-available-singapore
Alexz_Hong
yeah its nice. i want the wooky.
Soul. :p
Had a chance to play with my cousin's yesterday. Quite a nice phone actually, nice feel in hand since it's 5.0" only. Reminds me a little of the Nexus 5. Thought specs not that great, and the camera also not very good. To me it's a little too pricey for what the phone is, unless you really that "cute" factor. :s22:
cstanhwz
Hmm...what happens if both used the cheese shutter function together? Both said Cheese, Smile, LG, Whiskey or Kimchi together?
Can the LG G Flex 2 recognised the command said together by 2 person? :D
cstanhwz
At the moment 64GB microsd sd most worth and value to put inside Lg g flex 2. 64 plus 32 around 70GB of user storage for lg gflex 2
Yes, 64GB the sweet spot now.
LG G Flex 2 though had built in non-removable battery but this video shows easy to replace the battery~
All phone with built in battery, if the person knows, can still replace. Not just the LG G Flex 2.
Won't void warranty?
As usual, as long as you put all original parts back in the LG G Flex 2 and there is no sign of open before, warranty will not be void.
jtec14
haha. the best part about this contest is that you'll probably not see much new participants. The leaderboard is telling, I haven't posted in a while and am still on the leaderboard. :s22:. If you have not joined the contest on day 1, your chances are probably pretty low. So there is pretty much no reason for people to "join the discussion" so to speak.
I'm assuming that you can redeem the rewards as soon as you have reached the points required. Which means only 10 or so more days to go considering the maximum point of 43 per day. Also which means that those who participated earlier (meaning can obtain points earlier), would likely be the only who is able to redeem the LG G Flex 2.
But here's the fun part. For those tentatively in the 4th to 8th place, they have to make a choice to go for the printer or the phone. If they decide to go the the printer, they will be settling on a lower reward... but still a reward not the less.
Alternatively, they can try for the G Flex 2 in hopes that someone in the top 3 forgot to post, or unable to post. But by once they do that, i'm sure the 5 units of printer will be snatched up. If the earliest top 3 keeps up their point scoring daily, in the end they might end up with nothing to redeem at all.
But the contest runs until 25th may supposedly, so who know after everything has been redeemed, LG will add in more items as rewards... Or maybe they will introduce bonus points one of these days to mix things up a little.... who knows...
so.....
red pill or blue pill?
:s13::s13::s13:
hopefully LG add more items... :(
cstanhwz
If they knew about the issues in 810, why didn't LG use 808 for LG G Flex 2 too ?
Hopefully LG releases a software update to help reduce the problem in 810.
Think it was too late when LG knew about the heat issue. Already implemented in the LG G Flex 2 and should already be under mass production. Otherwise, think they would have stop and opt for the Snapdragon 808 instead of the Snapdragon 810.
base on past experience with LG~ their software updates is very wols~ only flash custom rom will be better but at ur own risk
Have to agree on this.
Use a fist or a palm to activate the Gesture Shot. No more stretching out your arm and struggling to press the shutter button. Take a better selfie without pushing any buttons by making a simple hand gesture.
Words like Cheese, Smile, Kimchi, Whiskey and LG for the commands.
Instantly see your latest selfie creation as the Gesture View feature opens your photo gallery as soon as you lower your G Flex 2 camera from position.
Is the 3 on the screen a count down? If yes, then got chance after using the gesture shot to move the fist away. Otherwise, like I said, it looks like going to box someone. :s22:
Otherwise, just use cheese shuttle to take. Using the Cheese, Smile, Kimchi, LG and Whiskey command to take than using gesture shot.
Nakedtoes
once u do the gestures can put down yr hand dude;)
WhiteHunter
based on past contest, they won't add in more items as rewards. once redeemed finish means no more but then they might start another one for LG G4 or LG Aka line.
WhiteHunter
the fist or palm is to start the countdown timer of 3 seconds. you can also use the voice commands like Cheese, Smile, Kimchi, Whiskey or LG.
