Ask a Bicycle Question - Part 5
rarenick
I always take out front wheel when keeping my bike at home. Then when I reassemble back for ride, the brake pad is always rubbing on the disc. Hence, I have to use an allen key to readjust the brake. Can this method be a long term solution for each time I want to ride or am I missing something?
Sent from me to you using GAGT
zeejayUU
if u need to do that because of lack of space, consider a folding bike?
g_t2006
Will it be considerably cheaper to buy a foldable bicycle, say Dahon or Tern in Shanghai or Beijing?
zeejayUU
Hi guys,
Looking at getting a road bike (total noob here)
Have been riding mountain bikes on and off (supermarket models etc.), want to get a ride that's smooth and fast!
Budget below S$1,000!
Thanks to any pros who can recommend any gear set/ places to try and visit or things to look out for!
just look at togoparts for used bike. u should be able to find a nice one for 1000. Unlikely to be carbon though
Just check the condition.
Sadisticnoob
you never insert in properly..
zeejayUU
how big a saving are you looking for. Actually if you buy used on togopart you can already get a good saving. There are lots on there for sale when I last looked
dilphinus
There are two kind of motors avaliable in the market,
one is crank powered
http://www.cyclone-tw.com/newkits.htm
the other is powered on the rear hub
no information cant have fair valuation lol
if you wanna get something for touring, get a normal geared bicycle
if your motor uplorry in the middle of malaysia roads whos gonna repair for you
most electrical motor range is only around 40-60km, i dunno if thats the defintion of touring
Can still paddle. Dont have yo use the engine/motor.
Anyway, shelving the idea of touring for now. Initial plan was to do a bicycle tour in the Netherlands. Purchase the bicycle there and bring back.
Any good recommendations for say a daily commute or a regular folding bicycle? Around 11km daily. No budget. Can spend $400+ to $800+ or $2k to $5k. Thinking if i should get a better bicycle eith the opyion for touring. Too many bicycles (8 or 10) at home (Dad's) so am more keen to get just one for myself.
My dad's bicycles are road and mountain bikes. I don't really fancy using one of his for a daily commute. I have my own transport but thinking of trying out cycling to work instead.
patcheon
Such a hot afternoon, so stayed at home cleaning and polishing up my bikes. And almost finishing the can of Finishline Showroom Polish and Protectant bought from SD on Monday. :s22:
DeadmanINC
wa lan si buay fierce bike siao :s22:
Sadisticnoob
I like the idea of a road bike actually, it's pretty fast and has enough gear ratios
But if you wanna a folding bike you can look at a tyrell or a Bromptopn especially if you have cash
IF not that much look at a dahon or even a Java
Take note of the price premium for foldie compared to mtb or road bikes
But generally, the more expesnive the better the quality
Well if you been to the Netherlands before, the idea of electrical bikes habe not catched on that well compared to Asian societies. Their electrical bikes has a speed limit of 60 which probably won't be legal here
SmilingDevil
Not sure about tern but for dahon, there are quite a few versions, international version, china version and japan version. From what I know, china version is the lowest standard. In singapore, we use japan version. In malaysia, international version. So u need to see which model you are getting.
SmilingDevil
I tried many times. I tot is quite straightforward n shouldn't go wrong? Is there a trick or two I can learn?
When u insert the wheel back, align the rotor between the clamp first b4 tightening it. If when u tighten it shifts to touch the pads, realign the wheel again holding the wheel with some force in the opposite direction b4 locking it again.
rarenick
Noted with thanks. Will try it the next time round
By the way do u sell stem that is around 70 or 75 mm long with adjustable angle? Prefer all black including the front face plate screws. Possible to go your Punggol park shop to fix it up?
Also considering suspension seat post if not too ex.
binary_0011
wah rich man, got own backyard. yes, today very hot. i cycled from bukit batok to changi and back , consumed 2 bottles of water, 2 cans of 100 plus, 1 glass of sugercane.
