Xiaomi Redmi 2 4G
ArcticCheetah
redmi%202%20spec_zpse59tn2jb.jpg.html
The China mobile redmi 2 enhanced version support WDCDMA, FDD-LTE
What I want to know is if the Redmi 2A can Unlock FDD-LTE a not.
If you can unlock the mystery then we can get a sub 150 phone for SG
China has FDD-LTE phones is already a know fact
csc12345678
I'm currently using HTC. It's browser has great reflow capability. I can easily zoom in/out and it will reflow the text nicely.
Is Mi Stock Browser able to do reflow ?
Thanks a lot.
Kennedy
my battery doctor app doesn't show up in the status bar of the screen. it is active. why ?
Solidus_GZ
I brought it
Not bad leh
Only complaint is cannot transfer app to sd card and see notification on lock screen
Other than that I love the 4g duel sim n the size of it
I'm speaking from a ex note 3 user point of view
Kennedy
did you try locking the app in the recent apps menu, by pulling down the app icon? In low RAM situations it will kill not-locked apps to free up RAM. :)
I locked the app but no icon on the status bar. in my other devices, the icon appears by default most times, or appears when I open the app.
dealova
I brought it
Not bad leh
But the bottom LED is blinking when there is a notification right ?
csc12345678
Just want to confirm if Redmi 2 can use Redmi 1 or 1s battery ? It's selling at $1/- only. So wonder if I should buy them together with the phone.
cscs3
Yes you can, just lower capacity. But $1 is good buy.
cscs3
But I'm myself going to get it soon ! My phone is too slow.
Play with Redmi 2 before. Is not so bad. Only down side is not dual 4G as per advertised. When slot 1 is on 4G. I can never select slot 2 to 3G. It always stay at 2G. This means by next year. Slot 2 is of no use.
oneboy
Both slots is 4G.... You can choose either sim slot for your data and it will be 4G. You cannot run data on both sim at the same time otherwise how will the phone knows which sim card to use for your data...
eaphla
Anyone having Redmi 2 enhanced, got problem focusing far distance object? Far distance object always blurred. Close shot is OK.
