Samsung GALAXY NOTE 5 Accessories
proproboy
sigh. might consider a plastic sp in this case. i use s-pen to do smart select a lot and it keeps "falling" into the gap where the sp ends and the edge of my UAG cover.
Which glass sp are you using?
Sent from Samsung SM-N920I using GAGT
Adolez
My Verus light silver crystal bumper finally arrived. Its beautiful! Here are some pix:
Will the back get greasy and slippery?
I'm using some cases and the back gets greasy and slippery very easily due to the material.
Wonder if the verus case is the same.
jollyboi
What's the best tempered glass sp for note 5 that can be bot online with no halo issues?
Sent from Nokia 3310 using GAGT
fabianlau
But one thing..it make it more bulky
renfred89
as long as you don't get those with full coverage, there shouldn't be the "halo" issue leh..
harky
anyone try the benks or Momax tempered glass ?
harky
or benks?
sian my fav
X-MAX like dont have note 5
savage
Sian. I wiped cache. Still same issue. Phone was kept awake by Android OS for 1 to 2 hours.
Battery drained 20% overnight...
What is the average battery drain for you guys overnight?
I never had a phone where battery drained so badly overnight.
typically is like 2-3% and max is about 10%... where got 20% one...
Foress
anybody got recommended portable charger? :D does fast charging work with portable chargers? thanks!
