iPhone 6s/6s+ Accessories Discussion (Cases/Screen Protectors etc.)
KwayChup
Now I using this case very slim but I feel not much protection.. Considering spigen which type would you all recommend?
blues7
Bought Apple leather case for 6splus
And privacy tempered glass cover
noobzpro
any where i can pay small fee to help paste SP ah lol....deciding between the ringke fusion and ultra hybrid now....my ultra hybrid on my n6 after a few times take off the plastic behind crack le
mikeeeey
Seriously. TG is damn easy to application with almost 0 chance of getting bubbles
moofiee
Cheap and good :)
yeap got this as well at $11 from Qoo10. One of the best around. Seller even used Speedpost. Got it after 1 day.
I bought the full coverage black, 0.1mm.
If you dont press the home button you wouldnt even know that a screen protector is on.
Only down side would be that its really not easy to align nicely. I had no issues removing and re-applying multiple times though.
Tried various non full coverage TGs since its most commonly used, always have bubbles/rainbow effect by the edge of the screen protector. Not to mention that the TG sticks out so much due to non full coverage.
overall view
side thickness.
misspotato
Very pleased and happy with my spigen neo hybrid ex rose gold. Perfect fit, seems like great protection and the colour is so lovely. I also bought tech armor tg from amazon, and the quality is amazing. When compared to nanotech under the light, tech armor has much higher clarity, seems like hd clear. While nanotech in comparison is not as clear. Waste my $10+!
KwayChup
Slim profile but with good amount of drop protection?
Spigen Carbon Rugged? Or other reco?
alan_shearer
overall view
side thickness.
nice! but so many sellers on Qoo10...which one is the right one who is good and fast (use speedpost)?
moofiee
Full coverage one trap alot of dust leh
you referring to those full coverage TG whereby the edges does not have any adhesive to stick onto around edges of the screen one izzit? thats why dust all go in from all sides of TG.
this one is whole piece full adhesive.
Jas007
I don't have any pictures to show but I can tell you the pros and cons
Pros: Good clarity, oleo phobic coating, I reapply it with no problems a couple of times.
Cons: Very hard to apply despite using hinge method, when I say difficult it is really difficult to align. Btw I pasted a lot of tg for other device and by far this is the most difficult
thanks for heads up
was about to order ...
think my pasting cmi lol
novatliz
Those who not confident pasting the TG by yourself, can checkout this mobile shop at Sunshine Plaza - Experience Mobile. I went yday.
They have various range of TG ranging from $3 - $30. Top up $2.90 for the application.
