Miyavisama
- Oct 8, 2015
How much would he charge for chemical cleaning for one unitU may call Mr Chua @ 96407449. He is my regular aircon servicing technician. He is very nice and quite friendly guy.
Hi Terumo,
I've a current aircon which is non inverter and now is partially down but i'm thinking of replacing with MIT starmax sys 4( 3 br and hall).
My problem is, current pipings are run under a raised floor and i wanted to run new pipings with another route. But i still need someone to remove my build in tv console( master aircon piping underneath), cut off cornice and cut out false ceiling in order to layout pipings to my other 2 rm.
Will you be able to recommend a good aircon installer and who will also be able to perform all those other task as above in order to carry out my installation.
If i will to leave the current piping alone as it is, will it cause anything?
Thank you in advance ..
Hello guys. My Panasonic aircon cannot turn on.
- Definitely not remote control
- Circuit breaker not tripped
Can any kind souls troubleshoot or recommend me a good aircon technician to fix please. Thank you.
Maybe next time you guys can engage Ah Yi serving
Ah Yi recommended link
He should do the different.![]()
Top up should be per compressor/outdoor unit.
It's pretty obvious. LOL.Mr chua and ah yi had been posting by the 2.same guy. Please be careful when engaging these air con guys. Ah yi had been mention that not replying calls.
Circuit breaker tripped when we switched on our Toshiba Aircon. First time it happened, managed to switch it back on after. Worked fine for a few days then it tripped again. Now we are not able to switch it back on at all.
Installed since early 2012. Any idea what could be the problem?
Thanks in advance.
