The hem needs to be either narrower or longer. The circumference of the hem should falls onto the shoes completely. From this angle, the circled part is "floating"
A better "no break" hem, IMHO
Jon, does this mean I need to get a narrower leg opening? I have very bad posture, and have quite a pronounced forward lean. I believe one of the things Matt did mention when cutting my pants is that he will cut the hems on a bias with the front being longer than the rear so that it will fall nicely on the shoe. That should apply here as well right?
Also, if the hem is narrowed does that mean the calves and thighs need to be cut smaller so that there isn't any awkward tapering?
Is that the standard cut from Sze Sze? I was about to try them but now I am a bit worried tbh.
Everyone has different tastes but personally I find the pants:
Too Short - nowhere near the bottom of your shoe in side profile
Too baggy below the ass - your calves are big so maybe it was done on purpose to make the pants look sort of proportional.
Crotch area looks extremely baggy - looks like it goes all the way to your knees
Bottom of the pants in the front view seem misaligned - it doesn’t flow straight down and is like 2 inches indented inwards near your shoe.
Dont mean any offense by this just sharing some thoughts.
To give some context, the pants are high rise, single pleat, with 2-inch cuffs. So it was made to my specifications. If you have your personal preference for the way your pants are cut I'm sure Mr Ong will be able to accede to your request.
With regards to length, I think jon hit the nail on it's head with his explanation..
I think the crotch looks that way in-part due to very poor lighting and also because I have a massive posterior and thighs. No thigh gap, single pleated, non-slim cut pants make the whole crotch area blend together.
The bottom two inches are the cuffs!
That's why it doesn't drape as compared to the rest of the pants. But I think other members have mentioned there's another issue with the cuffs.
No offence taken, constructive criticism will help me improve my future commissions!
