2.5 Gbps home network: wired and wireless router, NAS, switch and adapter
gundamkitten
Xiaomi 2.5G Switch with two SFP+ ports, even though Xiaomi calls this 小米万兆交换机, RMB 299.
https://m.mi.com/commodity/detail/20072
You can get cheaper switches with better HW spec. But Xiaomi brand may command some values for some users. Tear-down of Xiaomi 2.5G Switch.
https://www.acwifi.net/27700.html
DarthGW
any good unmanaged 2.5gbe switch to recommend? looking at 5 to 8 ports model
DarthGW
The guides from STH should be of good reference.
https://www.servethehome.com/the-ul...gear-hasivo-mokerlink-trendnet-zyxel-tp-link/
https://www.servethehome.com/mega-2-5gbe-switch-guide-update-with-21-new-models-added/
I tend to think is now more worth to get those with one or two 10Gbe uplinks (10Gbase-T or SFP+ port), eg, Hasivo S600WP-5GT-2S+_SE.
i read that review before but i couldnt seem to find these models on shopee or lazada..either that or the model costs more than $200+
closest will be the recommended qnap model but ship from Amazon UK
You may want to use Taobao, quite cheap.
Example:
Hasivo S1100W-8GT-1SX-S, 8 x 2.5G ports and one SFP+ 10G uplink, RMB 283.22 plus GST and shipment.
I myself have got the S600W-4GT-2SX-S model with 4 x 2.5G ports and two SFP+ 10G uplink, RMB 209 plus GST and shipment. S600W-5GT-1SX-S model with 5 x 2.5G ports and one SFP+ 10G uplink is at the same price.
https://item.taobao.com/item.htm?id=793617844986&ft=t&skuId=5416678228751
【淘宝】https://m.tb.cn/h.gRtMX7jobHzOvpB?tk=0UfI3cYqTiC HU0025 「海思视讯迷你型2.5G网管交换机路由器分流器网络分配集线器分线器」
点击链接直接打开 或者 淘宝搜索直接打开
My first ever Fibre optic related speed testing using iperf3.
1) Linux iperf3 server -- short CAT 6 Ethernet cable -- Hasivo S600W-4GT-2SX-S switch's 2.5G LAN port
2) Hasivo switch SFP+ port and Hasivo SFP+ optical module (10Gbps) -- 10m Fibre cable (Single mode dual LC-LC) -- Ganwen GW-9000-6XHML-X2 2.5G switch's SFP+ port with Hasivo SFP+ optical module (10Gbps)
3) Ganwen switch's 2.5G LAN port -- short CAT 6 Ethernet cable -- Acer Windows 11 laptop 2021 model with USB to 2.5G adapter, as iperf3 client
The results are as expected.
Bash:
PS C:\work\speedtest\iperf-3.16-win64> .\iperf3.exe -c 192.168.88.3
Connecting to host 192.168.88.3, port 5201
[  5] local 192.168.88.54 port 7000 connected to 192.168.88.3 port 5201
[ ID] Interval           Transfer     Bitrate
[  5]   0.00-1.01   sec   258 MBytes  2.15 Gbits/sec
[  5]   1.01-2.01   sec   254 MBytes  2.13 Gbits/sec
[  5]   2.01-3.01   sec   255 MBytes  2.14 Gbits/sec
[  5]   3.01-4.01   sec   256 MBytes  2.14 Gbits/sec
[  5]   4.01-5.00   sec   253 MBytes  2.14 Gbits/sec
[  5]   5.00-6.00   sec   255 MBytes  2.14 Gbits/sec
[  5]   6.00-7.00   sec   258 MBytes  2.16 Gbits/sec
[  5]   7.00-8.01   sec   258 MBytes  2.16 Gbits/sec
[  5]   8.01-9.01   sec   258 MBytes  2.16 Gbits/sec
[  5]   9.01-10.00  sec   254 MBytes  2.15 Gbits/sec
[  5]   0.00-10.00  sec  2.50 GBytes  2.15 Gbits/sec                  sender
[  5]   0.00-10.01  sec  2.50 GBytes  2.15 Gbits/sec                  receiver
iperf Done.
PS C:\work\speedtest\iperf-3.16-win64> .\iperf3.exe -c 192.168.88.3 -R
Reverse mode, remote host 192.168.88.3 is sending
[  5] local 192.168.88.54 port 7022 connected to 192.168.88.3 port 5201
[  5]   0.00-1.01   sec   284 MBytes  2.37 Gbits/sec
[  5]   1.01-2.01   sec   284 MBytes  2.37 Gbits/sec
[  5]   2.01-3.01   sec   283 MBytes  2.37 Gbits/sec
[  5]   3.01-4.01   sec   283 MBytes  2.37 Gbits/sec
[  5]   4.01-5.01   sec   283 MBytes  2.37 Gbits/sec
[  5]   5.01-6.01   sec   283 MBytes  2.37 Gbits/sec
[  5]   6.01-7.00   sec   280 MBytes  2.37 Gbits/sec
[  5]   7.00-8.00   sec   283 MBytes  2.37 Gbits/sec
[  5]   8.00-9.01   sec   284 MBytes  2.37 Gbits/sec
[  5]   9.01-10.01  sec   284 MBytes  2.37 Gbits/sec
[ ID] Interval           Transfer     Bitrate         Retr
[  5]   0.00-10.01  sec  2.77 GBytes  2.37 Gbits/sec    0             sender
[  5]   0.00-10.01  sec  2.76 GBytes  2.37 Gbits/sec                  receiver
iperf Done.
BTW, I have done the test using the above two switches and two SFP+ 10G copper modules from Ganwen. The SFP+ copper modules are quite hot but seems to work fine.
I am also using two cheap USB 4 to 10G copper network adapters from IOcrest and GRiS with my Mac Mini M1 2020 and my Windows laptops (Acer Swift 3 2021 model and Acer Swift 14 GO OLED 2024 model).
Reference 1: Hasivo switch test
https://forums.hardwarezone.com.sg/...or-wan-lan-port.7047645/page-4#post-153137858
Reference 2: Ganwen switch test
https://forums.hardwarezone.com.sg/...-simba-and-vq.6930337/page-177#post-153030287
IceWater_
Anyone tried using those Intel N100 passive mini PCs with 4x i226-V 2.5g NICs as a 2.5G soft router running pfsense/opnsense? I’m planning to get ViewQwest 3Gbps internet and use this as a router since it can be quite cheap if get from taobao, about $132 shipped for barebones then get cheap ram/ssd from carousell. Add in another taobao 2.5g switch for around $50. I already have separate APs.
【淘宝】限时官方立减19元 https://m.tb.cn/h.g9vtmraE6XBvL42?tk=rhDK3djmo6X CZ3458 「倍控N100工控机N200 I3-N305 N300迷你电脑爱快软路由ROS防火墙linux服务器嵌入式边缘计算」
Will i be able to saturate the full 2.5gbps duplex internet with this setup if i run opnsense barebones?
【淘宝】限时官方立减19元
1. No issues -- N100 is good for 2.5Gbps with pfSense/OPNsense/OpenWRT. I actually tested virtualized installation with my CWWK N100 mini PC with quad Intel-I226V 2.5G ports. But I am not using IDS/IPS. You should have no issues using baremetal (but not so sure if you use IDS/IPS).
CWWK N100 barebone: RMB799
【淘宝】https://m.tb.cn/h.g95ZjpH4ymQ7XVp?tk=FF7P3dQCtDh CZ3458 「畅网微控 N95/N100/N200/I3-N305/N300/无风扇低功耗 微型迷你工控主机软路由 英特尔12代N系列8核新成员」
But your one from 倍控 should be okay as well.
2. For basic routing, N100 may even be good for 10Gbps if you buy the version with dual SFP+ ports. But N305 CPU is better for 10Gbps.
3. I have bought Miniroute R1 N100 version (8GB/256GB at RMB1328) to use with my upcoming SingTel 5Gbps plan.
N100 barebone version: RMB998
N305 barebone version: RMB1658
【淘宝】https://m.tb.cn/h.gQwhftHv0o7w6w3?tk=2S0f3dQmdFl CZ0016 「超迷R1万兆10G软路由原生板载双光双电四网迷你主机工控机82599ES」
4. I have bought two Switches as well.
Hasivo 4 ports 2.5G switch plus two SFP+ ports, RMB 204
Hasivo 4 ports 2.5G switch plus one SFP+ port and one 10GBase-T port, RMB 399
【淘宝】https://m.tb.cn/h.gQwSl7Ym9TGuYhC?tk=OAN93dQNbvx CZ0016 「hasivo 2.5G万兆上行POE轻网管交换机企业办公猫棒VLAN猫棒网管型」
wkweksl
@xiaofan, a suggestion. You might want to include 10G and multi gig equipment in this thread now that higher bandwidth plans are available.
There is already an excellent thread which covers 10Gbps home networking. So this thread will be more for 2.5Gbps network even though it may cover switch and mini PC with 10G uplink but mainly with 2.5G Ethernet ports. You can say 10G home networking is the future and 2.5G is just a stop gap now that 10Gbps gears are still expensive.
10G Home Network and Home Lab thread started by @TanKianW
https://forums.hardwarezone.com.sg/...projects-include-10g-network-upgrade.6341518/
I have also started a thread which focused more on 10G capable router and switch with SFP+ ports.
https://forums.hardwarezone.com.sg/...port-switch-and-vq-xgs-pon-onu-stick.7047645/
Take note the future trend is to have Fibre along with CAT6 (or unshielded CAT 6A) cables for home. Post 10Gbps Fibre will be the way to go. There are two nice DIY guides from Appartus on how to lay Ethernet cables and Fibre cables
https://forums.hardwarezone.com.sg/...les-at-home-by-yourself-tips-for-you.7034845/
https://forums.hardwarezone.com.sg/...-lan-cables-to-10-25-40g-fiber-optic.7028716/
mountainlover
Kind of newbie in this area. I just got the UGreen 2.5Gbps switch from Taobao.
It has a 10G SFP+ port.
Is it possible for me to get a suitable fiber SFP+ transceiver to use for the new M1 2.5GBps plan so that I can skip the ONT unit? If so, which fiber SFP+ transceiver should I get?
You cannot do it easily. You cannot use normal SFP Module, it needs to be a GPON stick.
To replace the M1 ONT using GPON Stick (SFP GPON ONU) is a relatively more advanced topic. There is a thread about it and you can search in this forum.
Reference:
https://forums.hardwarezone.com.sg/threads/diy-ont-with-gpon-sfp-stick-and-openwrt.6771940/
https://forums.hardwarezone.com.sg/...nr-replacement-with-onu-or-pon-stick.6938685/
