4G LTE - Mobile Wifi / Wireless Router / Hotspot
keenklee
IMHO.
In another thread, someone ask a question. Just sharing some information from my test.
Mobile Plan - Heya.SG max speed at my location - 121/20.9
Client - Samsung Note10+
TPLink M7200 /$G LTE Mobile Wifi - 2.4Ghz
50cm - 20.3 / 21.2
300cm - 17.2 / 19.4
Prolink PRN3006L Smart 4G LTE Wifi Router - 2.4Ghz
50cm - 54.7 / 21.3
300cm - 21.4 / 21.5
Samsung Note10+ Hotspot - 5Ghz
50cm - 125 / 21.4
300cm - 123 / 20.9
Updated :-
Samsung Note10+ Hotspot - 2.4Ghz Reference : 122 / 21.4
50cm - 60.6 / 21.3
Samsung A14 5G Hotspot - 5Ghz Reference : 357 / 97 (Zym 5G)
Side-by-Side - 149 / 102
maumu
sorry but can you explain what the numbers mean? e.g. 125 / 21.4 is it the download / upload speed? in mbps?
boonkang
IMHO.
50cm - 20.3 / 21.2
300cm - 17.2 / 19.4
50cm - 54.7 / 21.3
300cm - 21.4 / 21.5
50cm - 125 / 21.4
300cm - 123 / 20.9
Can your Samsung Note 10+ mobile hotsport -- operate at either 5Ghz WiFi or 2.4Ghz WiFi ?
If yes, you should also test & compare results when operating the Samsung Note 10+ mobile hotspot -- separately at 5Ghz WiFi and 2.4Ghz WiFi.
This means comparing speed test results -- using the EXACT same device (Samsung Note 10 +) as hotspot -- but comparing:
- When Samsung Note 10+ mobile hotspot is operating at 2.4Ghz WiFi
- When Samsung Note 10+ mobile hotspot is operating at 5Ghz WiFi
boonkang
Can I get some advice if it's feasible to use it as a mobile broadband SIM card for home-based internet (via mobile 4g router)?
Seems like the download speed is not so good...?
Am currently on 500mbps fibre with Singtel but going to cancel it soon as my new place has no landline or fibre point.
TLDR (too long, don't read)
Over the years, I've used mobile hotspot quite a lot.
From my own experience:
(1) The single MOST important thing -- is that the mobile hotspot should operate/run at 5Ghz WiFi instead of 2.4Ghz WiFi.
This is because for WiFi -- 5Ghz WiFi can provide wireless clients with (much) higher bandwidth / speed than 2.4Ghz WiFi.
So you'll (usually) get higher bandwidth / speed if you connect to a 5Ghz WiFi hotspot -- when compared to connecting to a 2.4Ghz WiFi hotspot.
Nowadays we have 5G phones...
- if your phone connects to a 5G mobile network -- but your phone's mobile hotspot is operating at 2.4Ghz WiFi, then a lot of bandwidth is inaccessible or wasted because of the limitations of 2.4Ghz WiFi.
The higher bandwidth of 5Ghz WiFi hotspot is especially noticeable / useful -- when you share your mobile hotspot with many people and / or multiple devices.
ALL phones & mobile wireless routers can operate the mobile hotspot function at 2.4Ghz WiFi.
Unfortunately, not all phones or mobile wireless routers can support the mobile hotspot running at 5Ghz WiFi.
The additional problem is that:
-- Whether any phone or mobile wireless router -- can support/operate the mobile hotspot at 5Ghz WiFi or not -- is usually not clearly stated.
(2) The 2nd most important about using mobile WiFi hotspot is battery life.
Since phones or mobile wireless routers are portable -- you may want to use when you go out.
The battery life will determine how long you can use the mobile WiFi hotspot outside before -- you need to find somewhere to charge it.
Mobile hotspot function will use up more battery if there's a lot of mobile data usage through the mobile hotspot.
(Again) The battery life of the mobile hotspot is especially noticeable / useful -- when you share your mobile hotspot with many people and / or multiple devices.
If you use your phone as the mobile hotspot -- and if battery becomes flat before you can re-charge, then noboby can call / contact you while your phone battery is flat.
Previously I used a ZMI MF885 mobile router w/ 10,000mah battery -- because it is both a powerbank & also a 4G mobile wireless router.
Because of the 10,000mah battery, if I don't have too much mobile data usage -- the ZMI MF885 mobile hotspot can last more than 24hrs !!
Nowadays, I not longer use the ZMI MF885 mobile router -- because it cannot operate the mobile hotspot at 5Ghz WiFi (it only supports 2.4Ghz WiFi).
(3) The 3rd important thing about using mobile WiFi hotspot is whether there is any special requirements that is specific to your needs.
(3a) Some people use mobile wireless routers because some models have network / LAN port (e.g. Prolink DL-7203E)
You will NEVER get any network / LAN port on phones !! Haha...
The network / LAN port can be useful in different scenarios, some examples:
(i) You can connect to a LAN port in hotel / school / library to get/share Internet access instead of always use your 4G mobile data for Internet access.
(ii) You need to provide Internet access (via hotspot) to a wired-only device i.e. which don't have wireless capability.
(iii) If you have a network switch -- you can even provide Internet to many wired-only devices -- by connecting the network switch to your mobile router via LAN port.
(3b) Many people have dual SIM phones.
Some people prefer to use dual SIM phones as mobile hotspot -- because you can easily switch the mobile hotspot to use SIM 1 or SIM 2 -- without having to take out & swap SIM cards.
(3c) Any other reason you can think of -- that determine whether you prefer to use phones or mobile wireless routers as mobile hotspot.
Hope the above helps.
keenklee
IMHO.
I added in #1 for 2.4Ghz. The drop list like half.
keenklee
IMHO.
You can connect a USB Ethernet Adaptor to the mobile phone and share via hotspot.
maumu
how to check if my Oppo Find X2 pro (which I intend to use as a mobile hotspot) supports 5ghz wifi? Is WiFi6 the equivalent of 5ghz support?
also, since I only need it for my home (hence technically it's not 'mobile'), I can keep connecting it to a power supply so it remains always charging while it's hotspot-ing right?
have decided to go with heya.sg's 50+50 promo and test with the phone for wifi hotspot and see how's the speed and usage.
From Oppo FAQ:
Which devices might benefit from such a robust 5G + Wi-Fi 6 network? Your OPPO Find X2 phone certainly does! OPPO Find X2 and Find X2 Pro support Wi-Fi 6 and adopts dual-antenna and dual-frequency Wi-Fi, which gives you network connection priority under many circumstances.
From Oppo FAQ:
Correct me if i am wrong, but i don’t think the faq u sent is the answer to whether your oppo phone supports 5ghz hotspot.
I think this oppo faq u post here is talking about ur oppo phone being able to connect to a wifi 6 certified router and also can connect to 5G network, didn’t mention about supporting 5ghz hotspot at all.
Apex
"Most affordable hotspot routers offer a basic 4G speed of up to 40Mbps. It's important to check the 4G standard of the portable router. Many of them support speeds of up to 150Mbps, which translates to real-world speeds of 20 to 40Mbps. As for mobile phones, the 4G modems used are usually higher-end and can provide faster speeds."
Most portable router in category 4
https://www.cablefree.net/wp-content/uploads/2015/12/CableFree-LTE-UE-CategoriesMay2015-1.png
keenklee
From Oppo FAQ:
IMHO.
Go to your settings, look for Connections. Somewhere inside will will have Hotspot and AP Band.
AP Band should tell you if there is 5Ghz.
Wifi6 is not important but if have is good.
Do update here if you can find it or not. 🤣
maumu
yeah, I did some digging and found the settings.
indeed it supports 2.4 and 5 Ghz hotspot under AP band.
thanks guys for your sharing!
keenklee
Should be all phone will support 5ghz or 2.4ghz hotspot. My Redmi note 4 from 6 years ago is using only N, but hotspot can choose 5ghz or 2.4ghz.
IMHO.
Should be. 802.11a is year 1999 and 802.11n is year 2009.
