Hi folks, need some advice with a networking headache.
Just purchased a resale DBSS unit (TOP'ed in 2012) which has the FTP in the living room next to an SCV point instead of being in the DB cabinet. The fibre connection was probably done just after/around TOP hence its location; there are also no data points installed.
Previous owner on fibre used powerline networking as WIFI could not reach the master bedroom from living room.
Minimal electrical wiring is being done and I'm trying to avoid relocating the FTP given its distance from the DB cabinet. The "DB cabinet" is also an enclosure within the wall structure so placing a wireless router here will not cover the whole unit.
Parents want WIFI in the master bedroom and living room so I'm thinking of using two routers (1 as set as router the other as AP) and some modification to exisiting telphone wiring.
Assuming (1) the junction box for the telephone points is in the DB cabinet, and (2) wiring is at least CAT 5, would the following work?
TIA!!
Modification
1. Change telephone points to RJ45 data points
2. Install patch panel in DB Cabinet
3. Install networking switch in DB Cabinet
4. Connect data points in DB Cabinet to networking switch
Connections
LIVING ROOM: Modem / ONT --> Wireless Router -->T1
DB: Networking Switch --> T1 to T6 on patch panel
Bedroom 2 or MBR: T3 / T5 --> Wireless AP
TIA!!
Modification
Connections
