magicgunner
- Nov 3, 2014
Hola, I'm in the process of buying my PC parts and I just need some advice and compatibility checking.
(I tried using pcpartpicker but there are some parts that cannot be found there. Additionally, I live in SEA so some parts that can be found on newegg will not be available to me)
Budget: S$1.5k
CPU: i5-4690
GPU: Palit GTX 970 (4096MB GDDR5)
Case: Corsair Carbide Series SPEC-01
CPU Cooler: Coolermaster Hyper 103
PSU: Seaso*nic S*12II-*620 8*0+ Br*onze
Ram: Geil Black Dragon C9 1600MHz 8GB(2x4GB)
Motherboard: Asrock B85M-HDS
HDD: WD Blue 1TB
ODD: Samsung Internal x24 (DiscDrive)
OS: Windows 7 Home.Pre
Fan: Corsair Air Series SP120 Quiet Edition
Total:S$1484
Usage: Video+Photo Editing + Gaming
Anything I should keep in mind? Or are there any alternatives? (suggestions are welcomed)
EDIT: Formatting; dropped the "k" for the CPU; Swapped case; Added a additional fan
Budget: S$1.5k
CPU: i5-4690
HDD: WD Blue 1TB
Total:S$1484
