markipooboo
- Oct 21, 2013
Hey guys, just wondering if anyone has any cable management tips
I'm using those thin plastic strips where you have to twist it to keep stuff in place, (using that now because going to get GPU soon then will use a more "permanent" cable tie).
I don't use any 3.5" HDDs (probably never will, since SSDs are getting cheaper and will upgrade OS & programs to M.2, get another 500gb ssd to run raid 0 and use my external hdd as backup file drive)
So I have a lots of spare cables even though i'm using a modular PSU
4 Sata cables when currently I only need one and in the future only 2 maybe 3
4 molex when I only need one for the case fans
This is my first build so excuse the shoddy cable management...
Back view:
What it looks from the front:
the pump power for the kraken x61 is dangerously close to the fans connected to the radiator and the cpu power cables are also really close, any way to help that?
Where the excess cables are:
Thanks in advance!
Back view:
Thanks in advance!
