bornerwave
- May 25, 2013
Single colour nia. Might as well get from SLT. Only diff is that you cant control the brightness unless you set a fixed voltage on one of your fan headers.
Other than not being able to change color, this kind of LED strip also can get is it?
I think i read somewhere before this NZXT LED strip will short circuit is it?
Can still get. I wun say short circuit, more like LED die out.
I just took a relook at the link, it seems that it is embedded onto a wire. Which may mean that it will be hard for it to stick to the sides of the case.
On second thoughts, not worth. Get LED strips from SLT with 3M double sided tape.
. Btw, dunno is it you or shadow ask me check if define r4 can change the front panel door, I took a close look at my case today, the other side no front panel hinges so i dun think can.yup haha, anyway my rig not nice, so dun deserve LED for now. Btw, dunno is it you or shadow ask me check if define r4 can change the front panel door, I took a close look at my case today, the other side no front panel hinges so i dun think can.
I am shadow84....
KNN, 19 yrs old drunk le ah? Not even Wed, Fri, Sat sia... Ur monday blues so jialat?
i mean you or roy sorry![]()
Sim Lim Tower 3rd floor. Come up from escalator, 5 o'clock direction(?). Selling by meter.
