Changing battery
rob1977
Been using Xiaomi mi 11 lite 5G for 3yrs+. And it's still running well. Just tat the battery is getting flat easily. Anyone knows or can suggest where reliable to change the battery and how much they charge in total?
carboy00
Mister Mobile, ranges between 38 to 48.
Alternatively you can contact Xiaomi Service Centre for Out-of-Warranty quote, they quoted me 65 for Poco X3 Pro battery replacement.
Read HWZ Forum Rules on Poco F5 Pro
rob1977
But mister mobile not original battery. I'm waiting reply from xiaomi service center.
So in the end which one u went for?
rob1977
For my case,it's just battery replacement. Nothing much to talk about on. workmanship. Either make it or not
gobin74
hi , I am trying to charge a redmi 9t ..... but i am observing a strange behaviour.
The cable when connected shows that the phone is charging but it the percentage of charging is not going up ... It is showing as going down progressively ..Now it is at only 10 percent ....
I tried rebooting putting in software /firmware upgrades but of no avail... the charge is continously going down
Any pointers plz around this Thnx
ZhuTou!
I guess likely hardware issue like charging port. I think redmi 9t very old alr. Time to change phone.
andyhtc
Suspended
The battery may not be accepting charges, which points to battery failure.
froztheart
They have to open up the device either way isn't it?
So how does workmanship not come into play. But if you feel that its just a battery change then go ahead, just sharing here for you. :ROFLMAO:
froztheart
Port/Battery/Board/Cable/Power point issue likely too, needs diagnostic to identify what is the problem.
