Chaos erupts after powerbank catches fire mid-air on China–Seoul flight
singaporean11
CCC mark fail
This is China international flights lah, 'CCC' not enforced!
Even then, this is handphone (said to be a Samsung Note 7 - a well-known fire hazard that can burst into flames when charging) and not powerbanks that caught fire, and handphones do not need to be 'CCC' rated even in China domestic flights.
Time to mandate no powerbanks and handphones in planes' overhead compartments!
Hypernova
Maybe eventually power banks will be banned from air travel.
you need powerbanks then have to rent from local stores.
castafarian
A power bank caught fire mid-air on a flight from Hangzhou to Seoul, creating a panic among passengers and filling the cabin with smoke. The incident happened aboard a Air China flight flying at an altitude of around 10 kilometres.
stopped reading after "Hangzhou to Seoul"
orwell76
Root problem goes down to the factory that produce the power bank. Got to fix that If not it will just happen again
pmd also
Got disclose what brand the power bank? Shouldn't fix the problem if you get the drift.
I go ping duo duo and order
stupidog
I thought China alr mandated CCC certified power banks. how come will still have problems.
Unless some kkbs leave something charging, in the overhead compartment???
it's a feature...
C C C (See, see, see) got fire liao :s13: :s13: :s13:
NintendoSwitch
The fire is believed to have started in an overhead luggage compartment, where the device was stored. As smoke began to spread, flight attendants quickly rushed to the scene, grabbing fire extinguishers and working together to put out the flames.
The pilots immediately contacted air traffic control and requested an emergency landing at Shanghai Pudong Airport, but the crew managed to bring the situation under control before the aircraft touched down. All passengers and crew were reported safe.
A video of the incident has since gone viral online, showing flames suddenly bursting from an overhead compartment inside the aircraft. The clip captures moments of chaos as smoke fills the cabin, with startled passengers seen backing away in panic while crew members rush to control the fire.
In a statement on social media, Air China confirmed the incident.
“On October 18, on flight CA139 from Hangzhou to Incheon, a lithium battery in a passenger’s carry-on luggage stored in the overhead compartment spontaneously ignited,” the airline said.
https://www.scmp.com/news/china/pol...a-flight-south-korea-forces-emergency-landing
I tot Winnie forced travellers 3 buy his CCP endorsed powerbanks 4 air travel. Still chicaboomz?
558fe9b1-5fb8-4976-9f12-c510c8fb1278-jpeg.76788
BioProEng
this one is international flight, ccc cert not applicable.
singaporean11
Wouldn't it be more dangerous if an idiot passenger check-in the powerbank while charging a phone inside luggage at the same time?
What I mean is to mandate no powerbanks and handphones in planes' overhead compartments, and this is on top of current regulation where no devices with batteries etc (including powerbanks) are allowed to be in luggages checked in.
