Possible, nice or not is a different thing.
Can use pan to fry. Crispy on the outside, soft n chewy on the inside. Yumz
smlj.
Got so difficult put in boiling water meh.
eh dont bother cooking la
just straight eat it like that. let your stomach digestive juices do the work
Huh? You need to boil first right? You directly pan fry the inside will get cooked meh?Can use pan to fry. Crispy on the outside, soft n chewy on the inside. Yumz
fry aso can,,,Not reheat but to cook
Possible ?
idea sia. hope to see this in hawker centre.Can use pan to fry. Crispy on the outside, soft n chewy on the inside. Yumz
Yes can pan fry then add a bit of water and cover, very nicefry aso can,,,
can deNot reheat but to cook
Possible ?
No need. Straight from freezer to frying pan. Spray some oil, some water, about 3mins each side.Huh? You need to boil first right? You directly pan fry the inside will get cooked meh?
No need. Let me try to find the videoif ish those pre-packed freezer tangyuan, need to thaw before frying or not?
