CPU power up then stop
kitboi
my cpu suddenly cant boot up properly.
it will power up. cpu n casing fan will spin. then just stop.
this will keep continuing like endless loop.
the gfx fan does not spin.
any one encounter the same issue before? or know what could be the cause? :(
jtjt00
TS, list down all parts of your rig like those on the right -->
kitboi
rig was built in 2012.
specs below
i5-3470
asrock b75 pro3-m
gskill pc10600/133 4gb ddr3
powercolor 2gb 7850 ddr5
fsp 550w aurum series gold 80+ modular
win7 64bit premium
western d 1tb black
ZrE0_Cha0s
if u can see post click in to see the bios, if bios still cant hang on for even a min, probably ur psu cant handle or some of ur component is spoil/
kitboi
ah.. thanks for the tip :)
i tried to remove the RAM and gfx and it seems to be able to run without rebooting.
But once i slot back in the RAM.. the restart problem happen again.
ZrE0_Cha0s
den erase the gold contract on ur ram and try 1 stick at a time to see if the issues still presist or not
jtjt00
Either contact issue/dirty gold edge or your ram goes up lorry. If cleaning does not fix the issue, bring both stick to Corbell for RMA.
