wwenze
- Dec 2, 2002
0. Amplitude modulation issue
Use analog-in to avoid.
1. Subjective listening
Upon first power up, it was underwhelming.
After a while, it surprised me. It was pleasant. Surprisingly pleasant. To the point where I couldn't believe this is a soundbar and is produced by Creative and at this price.
And then after a while I found it missing some things again. And this gets very clear when switching back to my Usher S-520. And I figured out what made it sound underwhelming to begin with.
Because one whole big chunk of audio frequencies are missing. Ok, missing is an overexaggeration, but these frequencies are definitely lower in volume.
However, these missing frequencies are in the treble, which you can reduce volume by a lot and you would still think the sound is okay. Try it yourself if you don't believe me. Our hearing can actually remove a lot of >=4kHz and you would still think it sounds good.
And the rest of the frequencies are well-done in such a way that it does not sound obtrusive. So give a short time, and my brain accustomed to the sound. And it is a sound that I can accustom to. Unlike z623 and Leviathan for example… So we are already doing pretty well for the money already.
I overuse this description a lot - It sounds good until you have a proper speaker to compare against. But the Stage V2 is the truest recipient of this description - Subjectively, I think it might even be more acceptable than R1280DB on first impressions. Until you start playing some tracks that are more demanding and then the Stage V2 just sounds dead.
Oh and it also has less body and less bass than R1280DB. R1280DB's bass is just too madly good at this price point tho.
To Surround or not to Surround?
Quick first impression, both are decently usable and are both legit choices, although this is a description I fear have been overused too, since I've felt the same for Leviathan and also such sound effects in general. It gets even more complicated for sound effects that you can adjust the intensity of.
But what is different from the Leviathan, is the Stage V2 is a wide speaker (relatively for computer soundbars) and the drivers are placed far apart. How far apart? Well, like "the width of a 25-inch monitor" -apart. So it doesn't suffer from the "sound coming from the center" syndrome as much. It does suffer from "sound coming from the bottom" which is unavoidable for a soundbar but not as problematic.
And here is where the Surround effect comes in. Apart from making the sound sound like it is coming from a bigger speaker, it also gives the treble and the ambient a big and much-needed boost. Otherwise the speaker with the Surround effect disabled sounds constricted and dead and is certainly lacking treble and weight. On the other hand, turning on Surround effect screws with bass performance which is normal for this kind of effect.
The Surround effect works well, the speakers sound wider and further than my typical speaker positioning. It is set too strong for desktop in fact, but I can see this being useful for even bigger setups like bigger screens and TVs and you sit further away.
The problem is the bigger the surround effect you apply, the more it sacrifices the bass. And this is why I think both "on" and "off" are legitimate settings on the Stage V2 - When off, general performance is pretty ok, but it sounds like a soundbar with insufficient treble. When on, it sounds wider than it physically is and outshines even bookshelf speakers on a desktop, but the bass performance has room for improvement. Of course, the ideal speaker would perform well in both aspects, but when the speaker is not ideal it can only choose between the two. Fortunately both modes don't perform too bad in both aspects, but an option to adjust the strength of the effect would be nice because for my setup the best setting would be somewhere in-between. Personally, I think I will leave it on.
The Dialogue button and Surround button work independently, which is a bit of a surprise because surround effect screws with vocals and speech. Dialogue on makes the middle frequencies louder but I don’t feel it really improves anything else otherwise.
