Plse help me solve this problem.
At the utility room (DB area), i have M1 ONT connected to ASUS Router with 3 ports connected to 3 data points in the wall.
These 3 data points is wired to 3 separate rooms by Cat6 cable.
When I test my laptop speed via a Cat6 cable direct from the router, the speed is 300~400mbps.
When I test my laptop speed via a Cat6 cable direct from one of the room data point socket, the speed is 90~100mbps.
(only 1 pc is tested at a time, not testing 3 pcs simultaneously)
Both tests are using the same cable .. so this eliminates the cable issue.
I thought maybe the router divides speed by the number of outgoing port connections.
I called M1, they said high chance is because the data point socket cannot handle high speed.
Is it plausible?
I did some google but cannot find info that data point sockets have different speed type.
Anyone knows what could be the issue? TIA
Is it plausible?
