Hi guys, I think I may have crossed the line while turning right WHEN THE LIGHTS ARE RED (red right turn arrow).
Does the red camera take pictures of cars turning right?
The below is the stupid camera and junction
heh heh, near my hse, owas use this junction to turn right after exit PIE
u did the deed at night or in the day?
Yes, my colleague kana snap before when doing a right turn, U-turn will also kana. Both is only whether the cam can manage to snap your number plate or not, if turning angle too much and can't see your number plate, then you heng loh.
i want to know this as well.. beat the red light a few times while turning right ( so far ok )..
for the big traffic juncture.. i doubt the camera is able to take a clear shot of the entire width especially cars turning right.. basically i believe it only applies for cars going straight..
U turn will also kenna? How?
nope.. if you notice the ground, after the bold white lines, there is this box like black thin lines.. that is metal sensor. the camera is triggered only when it senses metal passing the first line, then to the second line, then no metal.is it more than 1 set of wheels trigger the sensor after the light turns red then kena?
that's at tamp ave 5. i ever saw a car turning right at the 3rd lane which was not suppose to turn right and he got snap by the camera.
if your car happens to stop above it.. it will not trigger
it also mean that if you have nth better to do, bring a metal rod in the middle of the night, keep passing it thru the sensor and the film will be used up![]()
tatsit - u sure is metal sensor?
your tire made of iron rite?
that's the cross junction at tamp~ i hvn't seem it flashes before~ so i guess ts is safe~![]()
