Drinking Distilled Water good enugh as Coolant Mix ?
human1969
Hi,
Trying to get some reasonable priced Distill Water as Coolant mix.
Are those bottled Distill Water sold in pharmacy (primarily for drinking water) good enough ?
I believe these are via reverse osmosis rather than distillation process.
Or anyone know if the NamWah Battery water (the only brand sold in most pump stn) is distill water ?
eg.
http://www.polar.com.sg/polardistilled
http://www.watsons-water.com/en/watsons_water.html
Thanks
IcYFl4mEz
those tapped water in bottled, kept in car boot for few days = distilled water liao
Asure7
Mitsubishi coolant (pre-mixed) even cheaper than Toyota... $18 only
hammee
I use Honda for my hyundai. It have lubricant for the water pump and less build up for my experience.
Infinite
anyone knows how to replace the coolant by yourself? I've no idea what's the current coolant being used and would like to replace the coolant. Don't think we can mix coolant right? lol
myviowner
If would be messy. Try not to DIY yourself.
Else check your over flow tank or open up cap of radiator(Open only when the engine is cold) to check the colour of coolant. Buy the same colour coolant.
Most coolant come pre-mixed. Drive to your trusted workshop and get it changed.
liquidh
At the bottom of the radiator, there’s a plug at the side. You open that up and also the riadiator cap and most of the coolant will be drained (except those in the engine).
After draining the coolant, you fill it up with the same amount that was drained with distilled water. Run the car for 5-10 mins.
Then, drain again. Repeat once if you are hardworking. Otherwise, top up with coolant recommended by manufacturer.
human1969
Is there a possibility of coolant being too thick if the water portion evaporate over long period of time ?
cscs3
Is very easy. Search Youtube, many video about it. You can buy those Pre mixed one.
cscs3
Always use Pre mix from start. Not distilled water.
Infinite
thanks guys, seems too troublesome to dispose off the coolant without polluting the drain. i guess workshop will be the better choice
Gymrat76
Assuming car still being serviced regularly, isn’t that a part of the service package? (Esp service from AD for newer cars)
