Nothing new here for the info can be found on the net
Ethernet LAN Cables
Pros
Fiber Optic Cables
Pros
Ethernet LAN Cables
Pros
- CAT8/9 can support 40/100Gbps up to a max distance of 30/100m
- Cables are stronger and durable than fiber optic cables against physical damage particularly when protected by foils and braids during laying and installation.
- One of the key advantages of Ethernet is its simplicity. Ethernet is easy to install and maintain, and it is compatible with a wide range of devices and operating systems
- Copper-twisted cables affected by EMI. Need shielding especially from CAT 6a onwards
- Cat 8/9 cables are very thick and stiff. Difficult to bend around corners
- Conducts electricity so there’s a fire risk if cable wrongly selected
- LAN cables cost more than fiber optic cables
- Has highest power consumption per RJ45 connector
Fiber Optic Cables
Pros
- Can easily support up to 400Gbps for kilometers regardless single mode or multimode ie. has high bandwidth capacity
- Good for futureproofing. If you are starting to totally wire up your house this is a better choice than LAN cables
- Cables not affected by EMI so data integrity is there
- Cheaper than LAN cables
- Uses light for data transmission so no fire risk
- Lower power consumption per connector
- Overall costs need to factor in the optical transceivers
- Their terminator points, adapters, connectors, and the panels and devices they connect to, all need to have some measure of EMI shielding to protect the data once it is transferred from the fiber optic cable to an electronic device
- The glass core strands are brittle and prone to breaking so more care is needed during laying, pulling and installation
- Compatibility between optical transceivers and devices may be an issue in a mix brands scenario
- Need more maintenance than LAN cables against dirt and dust which can affect the light transmission
