Fan replacement for gpu
jojo123
Hi.
I gpu fan is not working properly and causing pc to shutdown with high temp.
The graphics card is gt520 low profile. Any where I can buy the replacement fan for it?
Thanks in advance.
royfrosty
Hi.
Thanks in advance.
I'm not sure if your this unit has warranty. If not then i think its a bit hard to find a replacement fan for it.
If there is warranty just send back cause once you open it there is a chance of warranty being void.
Mycrus
My suggestion send for RMA if still under warranty...
Then buy a 2nd hand GPU in the marketplace forum...
When old gpu comes back from RMA - sell it off..
cKm
What I did last time, use a cable tie to tie a small cpu fan onto my faulty gpu. you can try that method.
