GrilledChicken
- Mar 2, 2023
Apologies in advance if this topic had been previously discussed often. I would like to build PC for the first time after previously only using gaming laptops. I'm hoping to build something that will last at least 4 years before I need replace any parts, and perform midlevel gaming. I will also be using it to stream privately to friends, and some basic photo-editing/painting/video editing.
This is my current build
https://sg.pcpartpicker.com/list/8NxLQ6
CPU: Intel Core i5-13600KF 3.5 GHz 14-Core Processor ($763.00) (bundled with motherboard)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler ($76 online)
Motherboard: Gigabyte B760 GAMING X AX ATX LGA1700 Motherboard ($0.00)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-5200 CL40 Memory ($235.00)
Storage: Samsung 970 Evo Plus 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive ($182.00)
Case: Corsair 4000D Airflow ATX Mid Tower Case ($138.00)
Power Supply: Corsair RM850x (2021) 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($193.00)
Operating System: Microsoft Windows 10 Home OEM - DVD 64-bit ($146.00)
Monitor: Asus VG248QE 24.0" 1920 x 1080 144 Hz Monitor ($135.00 2ndhand)
Total: $1792.00
Most prices are from Bizgram's list, except for cooler and monitor. My original budget was 2k including monitor, but I'm aware this current build has already exceeded, so looking to see which parts I could replace to still reach my aim and hopefully get as close as possible to 2k.
For this build, are there any parts that has mismatched performance with the other components, or perhaps unnecessarily powerful for the aims of the build? Is the overall price reasonable? I've deliberately left out graphics card, because I'm still not sure whether to buy new/second hand/local/international, but likely be going for rx6800, rx6800xt, or 4070Ti. Friends have advised that its best to go for 4070Ti for the software support, even with the price. What would be best?
I've also been told that 850W power is too much for the build, and I should switch to 650W.
I've seen several of the recommendations here, as well as prebuilds by different companies. Why are most of the advised builds use AMD cores instead of Intel? What are the pros and cons?
Total: $1792.00
