First PC build (Cad workstation)
Sndx_1020
Hi guys, this is my first build and I have no prior knowledge to building PCs. Would like to check if the parts will work together and if you have any recommendations that could cut down the cost with roughly the same performance, that will be great!
I will be using it for 3D Cad, rendering, 2D design work, animations and video editing. (rhino3D, keyshot, Adobe PS, Illustrator, ID, AE etc.)
CPU: Ryzen 7 1700x
GPU: Nvidia Quadro K2200 <buying off carousell most prob
Motherboard: GIGABYTE GA-AB350M-Gaming 3
PSU: EVGA SuperNOVA 650 G2
RAM: Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3000MHz
Storage(SSD): Samsung 850 EVO 250GB 2.5-Inch SATA III Internal SSD
Storage(HDD): WD Black 1TB Performance Mobile Hard Disk Drive - 7200 RPM SATA 6 Gb/s 32MB Cache 9.5 MM 2.5 Inch
Case: Fractual Design Define Mini C <can fit?
Also, I have no idea if I need to buy any additional cables (SATA etc.) thus advise would be needed. Most of these would be bought off amazon, excluding case and GPU, or are there any which might be chaper if bought locally? Thanks!
