Hi guys some quick question.
Putting together my rig tomorrow morning. .I unboxed everything already. Going with a define r5.
first off, I noticed the corsair h110 has some preset thermal paste. At least it looks like ready to use..should I remove it and paste my mx4 on it? Reason I ask is because im not sure if it is actually thermal paste..the surface looks weird.
The other thing is..should I mount everything on the motherboard first then put it into the casing? Or just mount the motherboard then put all the stuff?
My current rig I diy-ed myself was awhile back and it was a noctua D14..so abit simpler..put mobo, put everything else and then mount the D14. First time dealing with an aio wc with radiator and tubes so a little unsure about them.
I suppose ill be putting the radiator on top? The manual says its better as an air intake. .so. the fans in a pull configuration?
While editing my post I realised maybe I can mount the radiator first then leave the other end hanging...?
