anyone has any solution to this? or know where can i fix this?
there is rattle sound coming from my window when i hit on hump or uneven road.
very annoying.
driving a GE fit.
any help will be appreciated.
Got it once in my old car many moons ago. Jap car, not GE. Eventually found to be some cables loose. The mechanic took out those rubber tubing around the door frame and relay some of the cables there. Anyway, he say one. I did not see so cannot confirm.
very annoying.
driving a GE fit.
I have a GD1 and I had a similar problem. There is a slight rattle from my rear right door during turns, bumps, etc. I never found out the root cause but i solved the problem by winding down the window of the affected door by the tiniest bit. Just prevent it from fully shutted will do, without leaving any open gap.
very annoying.
driving a GE fit.
i tried and it works when i wind down the window a little.
However, when i wind down the window a little when driving pass vehicle. There will be wind noise coming from the tiny gap.
Any shop able to fix it?
