[Help] CPU cant power up
Nature_call
*issues resolved, if mod sees this please assist to close thread. ty
was watching youtube video suddenly cpu power down and unable to turn it back on :(:(
now when i try to turn on by pressing the power button the cpu stock fan spins for 1-2sec and then stops. after that continuously pressing the on buttons yields no result. have to turn off and on socket power wait a few mins then try again but same thing happens fan spins for 1 sec and stop.
whats going on?
specs as follow:
i5 3470
Asrock B75M-DGS
Seasonic 520w
128GB Samsung Evo SSD
Kingston Hyper X Blu 8 GB (2x4GB Modules)
HD 7770
Ottoke
Moderator
Moderator
Did you try to change the CMOS battery? It is on the motherboard
Nature_call
i only tried to reseat the CMOS battery (as i dont have a spare) and restart it by switching and reverting the jumper but to no valid. CPU is only 2.5 y/o, is the possibility of low battery possible at this duration? any idea where can i buy the CMOS battery easily w.o going sls?
TIA!
lcheowl
is the casing fan still running or also stop like the cpu stock fan?
jtjt00
CMOS battery CR2032 is available at NTUC as well as most mini marts. I think your PSU is a gone case liao.
Nature_call
case fan behave like stock fan, start 1-2 sec and stops.
i think it's my PSU, but no way to test w/o spare. any other methods to narrow further before i buy a new PSU :)
robolee
try this first
remove all your ram and clean up the contact point then reinsert - if still cannot
use an spare psu and test :3
nexusRAGER
Try and run the cpu, mobo and ram only.
remove rest of the things.
lcheowl
you are using Seasonic should come with 5 years warranty right?
Why not bring to corbell and let them check?
Danden
TIA!
Coldstorage/NTUC selling just ensure same model battery
lcheowl
Is confirm not due to battery.
If the battery is weak, the system will prompt him to go to the bios and will not shut down.
highly chance the psu gg. due to it cannot provide the enough power that why the system shut down.
TS should bring the psu to corbell to check assuming that his psu is as old as his rig.
Nature_call
I was in a hurry and wanna avoid the hassle of RMA. I went to a IT shop at causeway point and bought a master cooler psu 420 at $55. Plug it in and thankfully it works. I did not register my seasonic but got receipt. It's about 2.5 y/o so sayang, I rmb getting this brand despite it costing more. It lying on my house now, any idea what can I do with it?
Sent from LGE LG-D855 using GAGT
