help me build my PC
looking for the best parts. no holds barred
1. motherboard asus rog maximus xi extreme
2. cpu processor intel i9 core 9900k
3. graphics card - ??
4. sound card - ??
5. ram - ??
please help im noob :s13:
to clarify, i want to build PC for gaming and of course to surf internet and maybe edit some videos etc
games i wanna play include
divinity 2
cs
dota
etc
can someone advise me. i want to top of the line components cos i dont want to waste time. $ is not an issue
Bumiputera
4. sound card - ??
5. ram - ??
Just click the link before:
https://www.apple.com/sg/shop/buy-mac/imac-pro
and order the most expensive options.
Thank me later.
Rashkae
4. sound card - ??
5. ram - ??
1. Get a good air cooler / liquid cooling too.
2. GPU: 2080Ti
3. Sound card - no need, use onboard.
4. RAM - get 32GB G.Skill 3200 (Intel does not really benefit from RAM faster than 3200, but if it's no holds barred budget, go 4000).
-Synchronicity-
Best top of the line parts? Go for server grade stuff? Can on 24/7 no problem with ECC rams, double/triple/quadruple PSU in case of failure, fibre for tape library backups along with as many HDDs as the casing can support for RAID.
You know, in case **** happens.
narkizy
Server hardware perform alot worse than consumer-grade gaming hardware for alot more cost. Their purpose is as theur name states: SERVER USAGE. Not consumer usage. Totally not worth the money spent, bad comparison. Eg. A xeon processor performs much worse than a 2700x in gaming for easily 2x more the cost. Got money, spend it wisely.
-Synchronicity-
Firstly, op didn't mention anything about what he's using it for. Just the best of the best. Maybe he wants 24/7 usage with and do some mining, games as well as host some content? You never know what op needs especially since op didn't specify.
Secondly, op started a total of 2 new threads within 10 mins of each other posting the same thing. Not sure if he's trolling or anything but he/she obviously didn't read the pinned faq and do at least some homework and just want people to spoon-feed.
divinity 2
cs
dota
etc
narkizy
divinity 2
cs
dota
etc
Dont really understand tho. You wont waste time getting cheaper components either. Its literally two clicks to buy online *whut*
And at what resolution? 4k? 1440p? 1080p? Each res have different hardqare reqs.
Anyway seeing as you seem loaded af:
1) i9 7980xe
i9 7980xe alone is 5k sgd, up your alley ;)
2) 2080ti or Titan V
Titan V recommended, about 6k sgd.
You just google "Most expensive computer 2018" can liao ;)
Can use for: anything. Can help u cook dinner. Can be your wife. At this price, it can be anything u want it to be.
skate87
1) i9 7980xe
Don't forget to multi GPU and SLI it as well with a custom water loop =p
-Synchronicity-
You could start by helping yourself and setting a budget. If not, it seems more and more like a bad attempt at trolling.
