Thanks bro, what about the OS? Can I just plug and play using my old hard disks with Win 10?
Hi bros, For replacement of a new motherboard. May I know what are the things that I need to look out for?
Thanks in advance.
The new replacement motherboard must have the correct socket for the processor that you are reusing. Check also the new motherboard is using ddr4 or ddr3 ram.
If use back same hdd but with a new motherboard windows 10 might ask for new cdkey because the cdkey is tight to the motherboard. At least that is what happens to me when i replace my motherboard in the past. Other then that everything should work fine but can just reformat if you want to.
Check also if the new motherboard is able to fit in to your existing chassis. EAtx, atx, matx sizes etc.
Changed Mobo for 2 of my rigs before. U will need contact MS to reactivate both win10 and office.
Either u call during office hours or use the online help support. They will request u give them permission to remote desktop into ur PC and they will help u key in the activation code
The above only works for box versions. If u use oem them gg Liao. U need to buy a new key
