Marcus Rashford
- Oct 4, 2016
Any PC experts, enthusiasts can help? What's the possibility of the fault?
did u install pc speaker? tats y no beep.
try use onboard gpu 1st.
Did the onboard gpu still no display. I see the RAM got light. So don't think Its the RAM. This the 1st time build PC after many years. So Abit noob to say
resit the rams again??
must be sure it is fully inserted...
or just try with 1 stick first??
If the RAM got light, it means it sits correctly and working. Am I right?
maybe or maybe not...
last time i change gpu, gpu fan is turning but no display...
i resit it, then got display...
so i think the gpu might be getting some power but not fully inserted...
might be same for ur rams...
and when u test with ur onboard gfx, did u remove ur gpu??
You didn't test the CPU/Mainboard at the shop before leaving?
That time this happened to me, it's the mainboard that died. All the fans were spinning, but I still changed the PSU cos the fan was noisy and unsure if that caused the mobo to die, so didn't want to risk with a new mobo+CPU.
Bought long time ago, no guts to diy. No more warranty. Now then fix. So Abit lost already.
the cpu 4 or 8 pins connector got connect to mobo??
TS, list down all parts of your rig like those on the right -->
Asus Tuf b450m gaming pro
Ryzen 5 3600xt
Hyper x ddr4 ram 3200mhz
Zotac gpu 2080
750w psu
I did the onboard GPU after removing my gpu. Will try out the RAM again
