victorlee10
- Aug 1, 2011
Hi, lately I noticed that my PC will freeze randomly when in windows. Sometimes my mouse cursor can still move but everything else is frozen. Other times mouse can’t move at all. When I do a hard restart, I can get past the memcheck screen but will get stuck after that. I will get the message that OS not found on boot device. Going in to BIOS to investigate I can still see my HDD is detected.
If I leave the PC off for a couple of hours and restart it then it will start up and able to go in to windows as per normal and I am able to use it for a while before it freezes again.
I suspect it is a HDD problem but wouldn’t I get a “delay write failure” notice instead of the whole PC freezing?
TIA!
My PC is quite old
CPU: Core2duo e4500
Graphics: Onboard
HDD: 4 HDDs bought over many years
Motherboard: Asus
Ram: 2gb Kingston ddr2
Power supply: Came with case, recently changed 1 year ago
OS: winXP
TIA!
My PC is quite old
CPU: Core2duo e4500
Graphics: Onboard
Motherboard: Asus
OS: winXP
