Help: Pc keep crashing > blue screen
  • Need someone to talk to?
我猜我猜我猜猜猜
I tried
  • reinstalling both my video card
  • reformat pc
Pc still crashes randomly i done a stress test it doesn't crash.
Pc specs
Psycovirus
我猜我猜我猜猜猜;112143418 said:
Yup, but i uninstall it and reinstall a fresh copy of the driver problem still occur.
What game are you trying to run? Or what were you doing when it crashed?
singupingu
Gpu looks really warm at idle (52 deg)
I'm suspecting the gpu problem.
Sent from Finally Unbanned using GAGT
我猜我猜我猜猜猜
Psycovirus
我猜我猜我猜猜猜;112168182 said:
Damn it's just a 1 year old gpu. :(
It happens randomly.
Tried the method from another forum still no uses.
I see. RMA the GPU... It's crashing randomly. Symptoms of dying soon.
Sent from OnePlus ONEPLUS A3000 using GAGT
Encrypted11
It's some of the list of things people on guru3d ati driver subforum try to work around on and off for years.
Normally they mix old parts of a working driver release implant into the newer driver (not recommended at all). Rather than driver modding just try an older release first...
我猜我猜我猜猜猜
Looks to be a driver TDR issue.
Try using older drivers the driver (when ur gpu was still the primary product) development for 300 series ended at Radeon settings 16.6 before they merge in polaris.
https://support.amd.com/en-us/download/desktop/previous?os=Windows 10 - 64#k=
make sure you use display driver uninstall utility first.
Noted i will try it.
