I have a 500gb WD elements portable drive connected by usb port only. Recently I have impossibility slow or non-readable access the drive via the usb port, and keeps blinking white light.
I've sent for quotation for harddisk data recovery, and requires about $900. However, I suspect the harddisk is actually functional but the USB port connect is the one at fault.
I've open up the portable drive to find that it is not like the normal SATA drive adapter, but has the USB directled soldered on the PCB. Thus i cannot use this harddisk into another portable drive housing.
Does anyone know a place whether the usb port can be replaced by a trained person? i really want to extract the data from the drive but it cost so much to do a data extraction through those companies.
