Help review my purchased rig
matwee
Hi Guys , need help to review and see if got any changes to be made as i went down today to buy last min. and ask them to build tomorrow, then i collect.
so i wonder if got any last min changes can be made.
i3570k
Asrock Z77 extreme 4
MSI gtx 670 power edition OC
antec 900w psu
samsung 840 128 GB ssd
Hitachi 7200rpm 1 tb
Kingston HYper X 4x2 GB
LG 24X DVD RW
pls need urgent attention
thanks a lot
:s22:
in addition, anyone with sli 670 have any benchmark for crysis 3
as i saw in the web many different type of benchmarks performance that may be due to many other factors.
i hope to play at ultra setting, 8x msaa, AF 16X, all max settings..at two screen 1920*1080*2.
MoneyFace =p
Please change SSD to something else, ideally a Plextor M5 Pro Xtreme, at all cost. TLC NAND will not last long.
And downsize the PSU to Seasonic X/P-660/760 will do. 900W is way overkill and Antec's warranty is short and PSU is inferior to Seasonic X in all aspect.
straweffigy
FPS how to play on 2 screens.. Crosshair in the middle will be split?
dinosau4
Good motherboard, Overkill Psu, Underperforming HDD. Better RAMS imo ? :D
matwee
ok i take note.
i using a lian li case ...... do i still need cpu cooler cos the person say don't need?
MoneyFace =p
ok i take note.
Yes if overclocking (which is highly probable since you're getting a K series CPU)
But you can choose to get it at later time when you want to OC.
MoneyFace =p
HDD performance is not an issue for sole personal data storage. Higher speed RAM doesn't translate into justifiable better performance. It is instead better to scrimp on RAM especially in these days.. :o
matwee
yah i thought so after various lessons on ram from the forum.
thanks all for your kind advise to a noob or technical idiot
what market cooler u all recommended then?
MoneyFace =p
Xigmatek Gaia from $37 for a good start.
Cooler Master Hyper 212 Evo from $59 for a very value and great performer.
