Help solve PC problem
winthony
My pc specs is at the right ----->
So recently when booting up my pc till desktop, i can use my pc for awhile before the pc freezes and my monitor just stop having any input but my cpu is still running.
Thus I will be a hard reboot by holding the power button but whenever i restart my pc, it takes several times before i can boot up to my desktop.
Sometimes the monitor will display no input or the words are all scrambled during the bootup process ( the window is starting and the window logo is scrambled or the AMD bootup screen with the ram and stuffs are all illegible )
Any idea whats going on?
xkiller213
sounds like graphic card problem, or (less likely) ram...
remove graphic card, remove dust from card, try again...
winthony
i will try the graphic card part.
dust from card you mean the contact point?
