Help! system wont boot up
petrarchan
need some help..
system SB mobo lights are on but cannot power on
Mobo: Asus H97M Plus
CPU: G3220
Rams: Crucial 4gb 1600 (1 stick)
no gpu
SB power led light on (got power)
DRAM light off (so rams ok)
GPU boost light on when i switch the lever to the other side)
no beep sound, the cpu fan doesnt spin.. psu fan doesnt spin.. what could be the issue?
ZrE0_Cha0s
May I ask does your mobo lights indicated have those error codes?
can u check is there any loose cables?
petrarchan
ZrE0_Cha0s
what is that lever?
anyway maybe u can check with lose cable inside or outside of ur case?
if all problem check and no issues, maybe u have to try another psu to see.:o
petrarchan
what is that lever?
i took the whole mobo out..
swapped psu and power buttons..
if rams or proc issue at least the mobo would boot up but will have beep sounds or wont go into windows..
ZrE0_Cha0s
do u have thermal paste? if have take out ur cpu cooler and check ur chip.
petrarchan
checked..
guess what.. it was the power switch connector at the mobo.. not sure how come the 2 pins lost contact with the case power on switch internals..
weird issue..
ZrE0_Cha0s
checked..
weird issue..
lol really?
but still kinda weird though..
petrarchan
lol really?
yup.. also didnt work with my another power button
i went to use a screwdriver tip to connect the 2 pins on the underside and it worked.. then used it on the surface 2 pins and it worked from then on.. yes its a weird issue..
petrarchan
TS, which casing is that?
bitfenix
but it doesnt seem to be the casing issue as well, cos i tried another power connector and button, same cannot power on, till i decided to troubleshoot by shorting the power connectors on the underside of the mobo which worked.. then tried again using the power button (usual way) and it worked from then on..
really weird.. first time experiencing this.. almost wanted to take it to the service centre tmr.. heng ah.. otherwise the tech there will :s13::s13::s13:
