Hello all, I would like to build a new rig. Looking at mitx/matx because the cases take up a lot less space. I need some suggestions and recommendations.
Usage wise: Would like to play games like dark souls, skyrim, bioshock infinite on best settings. Usually leave my com on 24/7 so stability is really important. Occasional video editing. Oc wise, I normally use auto oc. Not garang enough to try manual.
Appearance: Thinking of white/black/gold or white/black/red colour theme
CPU: I7-4790k
Mobo: Not sure which to pick
GPU: Gtx970
PSU: Seasonic x-850 (enough power?)
Ram: Any 2 x 8gig
Cooler: Corsair h100i
hdd: Seagate 3tb x 2
ssd: plextor or samsung 240gb~256gb
Case: node 304 / corsair 250d / nzxt 440 all look very enticing
monitor: I do a lot of document work. Not sure if 2 x u2414h better or 1 27~28 monitor better. I don't play fps games competitively so I'm not sure if high refresh tn panels are better for my use or ips types like the dell 2414h. I do watch quite a number of films on the com though.
Budget wise 2.5k to 3.5k (including monitor)
Thanks in advance
CPU: I7-4790k
GPU: Gtx970
Ram: Any 2 x 8gig
Thanks in advance
