how does massage works?
heroking
let say my neck very sore
then i go JB massage
massage 1 time will ok already?
or need to frequently go for the soreness to cure?
Shingoz
neck sore go body massage?
it's when your other area is sore... not neck :p
Thoreldan
@crimsontactics for sexpert advice.
Edit: Oops, didn't know he tio banned.
kuti
Just go frequently till no sore or you tired of her looks.
Change a new one and rinse repeat
AuraKUPO
If the technique is right, can hit your spots, one time you can feel the difference. If want to improve or heal something, need to go many times.
That's why last time I got regular vnb therapist. Once found don't let go, she went back vn I still go find her
NintendoSwitch
Do you watch cat videos? The meow meow will massage each other. As for your issue, it depends on the severity of your soreness cum the skill of you masseuse. I had frozen shoulder and visited so many to try to fix it. Some hopeless. Some worse. Some no effect. Last weekend finally found one that made it improve. So you will need to find a highly skilled one.
EdenHazard
Sonetime is not the neck but other parts that need release. Frequent treatment is good. Need find a good therapist
Senfai
It depends on the root cause
If never sleep well, wake up neck sore, massage one time see improvement and relief
If neck sore due to bad posture, long hours standing or at desk bound job, massage won’t fix the root cause, it will keep coming back and you keep going
After a certain age, the soreness is like an old ailment at the core of your muscle already, very hard to treat.
qcy888
Will 1 massage be enough?​
  • ✅ Yes, sometimes — if the soreness is mild, from short-term tension, bad sleep posture, or a stressful day.
  • ❌ Often no — if the pain has been there several days, keeps coming back, or feels stiff/deep.
A single massage can:
  • Relax tight muscles
  • Improve blood flow
  • Reduce pain temporarily
But it doesn’t always fix the cause.
When do you need multiple massages?​
You’ll likely need regular sessions (e.g., 1–2× per week for a short time) if:
  • Your neck is sore more than 3–5 days
  • You work long hours at a computer or phone
  • Pain returns after massage
  • Neck feels stiff every morning
  • You have stress-related tension
Massage works best cumulatively, not as a one-time “reset”.
What actually “cures” neck soreness​
Massage alone isn’t enough. The best results usually come from combining:
Massage
  • Relieves tight muscles
Daily habits (very important)
  • Adjust screen height (eye level)
  • Avoid looking down at phone for long periods
  • Use proper pillow (not too high)
Simple exercises (2–3 min/day)
  • Gentle neck stretches
  • Shoulder rolls
  • Chin tucks
Heat
  • Warm towel or heat pack 10–15 min/day
⚠️ When massage is NOT enough​
See a doctor or physiotherapist if you have:
  • Pain lasting >2 weeks
  • Numbness or tingling in arm/hand
  • Sharp or shooting pain
  • Pain after an accident or fall
  • Headache + neck stiffness + fever
Practical recommendation​
  • Try 1 massage first
  • If pain improves but returns → do 2–4 sessions over 1–2 weeks
  • At the same time, fix posture + do light stretches daily
