How often do u top up gas for air con?
notbui
As above.
When they come to clean your air con, do you ask them to check your compressor to see if need to top up gas?
How often you top up gas for your air con?
randyap
but my air con like after ask them to come to clean, still need to on for a few hours than will cold.
so I think could be not enough gas need to top up...
few hours is definitely an issue. ask the aircon man to check pressure, topping up should be rare, might be other issues.
BrOwnTeddy
As above.
3yrs already.
only need to top it up once. And it was like under 2 or 3secs. Very little only.
wltwow
Actually, how long can the gas last? My unit have not topped up for 4 years already, still cold tho.
KYZT2021
Make sure AC is clear and filter got wash first, then really not cold then top up
light84
Aircon gas no need top up. It’s a closed system.
Do u need to top up gas for your fridge?
Dun be carrot head
Darkshadows
As the saying goes, don't fix it if it ain't broken.
Who knows you get the aircon service guy to do some "checks", he instead sabo your aircon and steal the gas/cause a leak so that he can charge you by topping up your gas.
