I am using dell u2311h 1920x1080 and I find that it is too small to use 2 windows side by side easily (split screen into left and right part), 2 windows are quite small and need to scroll sideways also, so I do not use 2 windows split screen often.
You guys using 24 inch 1920x1080, is it too small to use 2 windows?
I thinking of getting a 24 inch or 27 inch monitor. 27 inch should be easily fit 2 window with good size each, but not sure about 24 inch so asking.
Thanks
Thanks
