Is there a Bluetooth function to connect laptop to monitor?
WhiteAnt
The cables are so messy on the table :s15:
Anyone knows if this is even possible?
DarkStarer
Use screen cast. But the casting not instantaneous.
Best is still HDMI.
Lonewolf83
Don't think got laptop can link by Bluetooth ba...maybe link to projector more possible
Seah.tt
Means your monitor has to run some application in it ? Which means it need a hdd ? Sorry i noob.
i nv use b4, need both monitor and laptop have the technology. for monitor, is possible to get dongles connected to HDMI
batuchka
well your monitor has to have the tech to receive BT and convert it to display and also the bandwidth or data rate of BT dun think can sarpork high resolution and/or low latency so BT currently isn't used for wireless display and wifi is preferred me thinks?
Mystyque
Attach a dongle to your TV/monitor then your laptop connects wirelessly. Quite laggy IMO, watch movies the sound and video need to manually sync iirc.
86technie
Don't have, even if it will be very horrible to use.
Cuz BT bandwidth is very slow so your image will either flicker or very slow that
you think your PC got problem.
Depending on your laptop model, some laptop have docking station.
That docking station is where all your cables are connected to, Monitor, mouse etc.
If you need to remove the laptop just disconnect the USB-C cable and that's it.
Geneco
Bluetooth won't have another bandwidth to carry your video signal...
Wired is always best.
jack-320
You need a switch/KVM switch/HDMI wire
never heard of such Bluetooth function
guile
You can get wireless HDMI though. Connects to your devices HDMI ports.
SG$ 49.42 13%OFF | 50m Wireless HDMI Video Transmitter and Receiver Extender Display Adapter Screen Share Switch for PS4 PC To TV Monitor Projector
https://a.aliexpress.com/_mPo1urY
Less than $100 for a pair. About 50m line of sight. Sometimes can go through walls depending on thickness and yr home RF environment. Both need to be powered though, usually can be powered via USB as they take about 5w each. And they can run pretty hot so have it well ventilated. These usually have the least latency.
