I does a tracert to a aws IP address and noticed that on the 10th hops it start to have latency. I've checked DNS whois (http://wq.apnic.net/static/search.html) on that IP and found that is singnet entity in telepark. What can I do about it?
Nothing much a home user can do. Why are you doing this tracert? What is the issue with your internet?![]()
Not just ST will not entertain, other ISP will also be the same unless there is connection issues.i doubt ST will entertain route optimisation unless theres connectivity issues..
It is likely hop#10 from your tracert seems to be their oversea POP (USA) where hop#12 maybe a ST peering in USA LAX? if it is the case, the latency from Singapore to USA for most of SG ISPs will be ~180-250ms (from my experience) depend on the US end host location. The latency might due to geographical distance between SG-US where it has to travel through the subsea cable from SG - USA, as you cannot request a latency value similar to local SG latency for a host in USA. For IP location database, it might not be always reflected accuracy as the ISP may register the location for their whole IP supernet in their APNIC but they can use smaller IP ranges somewhere if they have oversea equipment. Better check with ST as well.
