laptop problem
harky
i had this Xiaomi laptop which i use like 2-3yr ago.
recently it auto shutdown after a while... today try to use, same but after auto shutdown... it nv wake up!!
try to plug in power plug, also cannot turn on..
hmm usually auto shutdown mean which part got issue ah??
the latop very gd u know.. so i want to fix it if i can le
tszkitc
Maybe something wrong with the FAN, overheat so auto shut down......
watzup_ken
Check if the fan(s) is spinning. I feel it could be that something failed on the motherboard. How long does it usually take for it to auto shutdown?
harky
think 10min to 20min..
it been like tht recently.. but i hardly use the laptop le. i use desktop most.
sian now cannot turn on liao. think later i open up and see see...
harky
i remove the battery.. but no power light.. isit gg?
try this.. but only blink one time..
