less than $2000 pc build
laser168
looking for a desktop build that is less than $2000. will be using it to play cs go & dota 2 and some photo editing only. hope can use gtx 1070 & also I wont be overclocking.
dgenex
$2000 need Monitor or other peripherals?
And aesthetics important?
dgenex
CPU + Mobo : R5-1600 + ASUS B350M-A ($470)
GPU : Zotac GTX1070 Twin Fan ($609)
RAM : Kingston 2133MHz 16GB ValueRAM ($162)
SSD : Samsung EVO850 250GB ($159)
HDD : WD Blue 1TB ($72)
Casing : Fractal Design R5 ($169)
PSU : Corsair TX550W Gold ($143)
Total : $1784
Prices from PCThemes. Source components from multiple stores/online might be cheaper.
OS can get from Carousell for less than $20.
HDD/SSD Size depend on how much data you need to store.
GPU chose Zotac for 5-yr warranty.
Casing should go and see what mATX casing you like, Fractal Design/NZXT/Phanteks cases quite nice imo.
singupingu
Total : $1784
Wah bro. Your recommendation tok gong!
Sent from Overpowered Phone Mark III using GAGT
laser168
Total : $1784
sorry to ask stupid question amd processor good?
wah os $20 where to find?
singupingu
Look at my specs on the right :) 6 cores 12 threads for the price of 4 cores 4 threads on Intel side. So far looks okay, my most recent games I bought recently is Deus Ex Mankind Divided. Looks good, plays well, no issue whatsoever. Even overclocked to 3.75 GHz on all 6 cores with stock cooler.
Search on carousell. We cannot link you directly to seller. Haha.
dgenex
Look at my specs on the right :) 6 votes 12 threads for the price of 4 cores 4 threads on Intel side. So far looks okay, my most recent games I bought recently is Deus Ex Mankind Divided. Looks good, plays well, no issue whatsoever. Even overclocked to 3.75 GHz on all 6 cores with stock cooler.
Yes, definitely go R5-1600 over i5-7500. I really regret not waiting awhile more for Ryzen. But Uni holiday start I too eager to build lol
:s22:
xiaozozo
OS just get reddit, keyword microsoft software swappppppppppppppp
