- Sep 16, 2018
Original post on 3-March-2024.
Usually I will recommend solution > S$200. For example, the minimum Asus router (main router) I will recommend is Asus TUF-AX4200 which is already at around S$229. Then sometimes an extra node is needed which I will recommend Asus RT-AX3000P at around S$80, total cost will be at S$309.
I will still recommend to go with the better router you can afford. But it will be interesting to know people's recommendation for <=S$200 solution and even <=S$100 solution. I am not good at finding lobangs so maybe the people will have better ideas.
The discussion below should be based on an assumption that there is no ISP issued router in the picture. For example, if you go with M1 500 Mbps plan there will be no router provided. Or if you go with no-frills plan with no bundled wireless router.
Edit to add on 6-March-2025.
Now no-frills plans are popular, from ISPs like the low cost providers like SIMBA and Whizcomms. Then ViewQuest and MyRepublic also offers no-frills plans.
The post also applies to those cost concious users who are still using very old routers (eg: out of contract) or those who have sold the bundled router to have low effective cost (eg: M1 users selling the bundled Archer BE805 or Asus ZenWiFi BT10).
For those who want to reuse old routers or buy old routers, please read Post #34 of this thread about security fix support status. Out of support routers can post great security risks for your home network (eg: virus, spyware, ransomeware, botnet, etc).
https://forums.hardwarezone.com.sg/...ypical-hdb-flat.7006182/page-2#post-155509541
Edit to add on 9-March-2025
Asus EOL list: Asus has EOLed all the consumer AC routers, as well as RT-AX56U_V1 and RT-AX92U.
https://www.asus.com/event/network/eol-product/
TP-Link Duration of Security Support
https://www.tp-link.com/sg/support/faq/3182/
Netgear Singapore Home product EOS list
https://netgearstore.sg/pages/end-of-service-for-home-products
Linksys EOL and EOS query
https://www.linksys.com/pages/linksys-product-end-of-life
D-Link Singapore EOS list (old info, as of 30-Sept-2021) -- D-Link DIR-865L and DIR-868L have been out of support for a long time.
https://www.dlink.com.sg/Downloads/EndofSupportService.pdf
Singtel router support info
https://www.singtel.com/personal/support/broadband/routers-ont
Starhub router support:
https://www.starhub.com/personal/broadband/routers.html
https://www.starhub.com/personal/broadband/routers/smart-wifi-series.html
https://www.starhub.com/personal/support/article.html?id=LfNB5odcBt0mTG6Pr7GSB7
