Shahmatt
- Oct 2, 2006
I recently purchased a Hopi HP-8 power meter from Aliexpress for 39USD. So just to share...
My friend in the electronics industry recommended this brand as they make true RMS (root mean square) power meters. True RMS take into consideration the phase difference between voltage and amps for power calculation. This is more accurate compared to the cheaper power meters in the market.
Some images below. First the box:
The instrument with manual and supplied adapter. The instrument plug is a china style 3 pin plug. Some minor scratches on the screen but it did not affect readout. Instrument is light weight but with good plastic build quality. The adapter feels cheap and I did not use it.
English instructions in the manual:
Readings with my 2400W Braun iron in uH mode (energy use mode):
Display shows Current, Voltage, Power, Power Factor, and the last line is APC or UH. Below the power socket is two entry points for live and neutral wires should you wish to test that way.
I noticed that the SG square plug does not fully seat in the socket as the wire connector openings protrude out and get in the way.
When set to APC it provides a kWH/year measurement - you can set the estimated number of hours use per day and it will give you a value based on what is measured right then and there.
So for my 2200G build (see signature right ->), if I set 24hrs, then the idle kWH measurement shows around 350 kWH. Based on 22.15 cents electricity cost the annual cost of running 24/7 is SGD 77.5. Actual usage may be 2 to 3 hrs per day but this is just to get an idea. I also found out that this PC consumes only 95W on max load prime95 blend test.
I have not tested the uH measurement properly yet but it is an energy used measurement and cumulative - i.e. you can reset to zero and it will keep increasing until you reset again. I'm guessing it is more suitable for use with appliances like fridge or aircon which cools intermittently over the day and night. Will update this review after using on my fridge for a few days.
Thanks for reading.
Thanks for reading.
