Mitsubishi electric vs heavy industry aircon?
thriller-sama
home use use mitsubishi starmex.. heavy industries cheap but not so efficients and part not so easy replace. hearsay.. anyway the advice i had is just consider starmex or daikin.
i heard starmex much prefered cos the part easy and cheaper to replace if required
chaiscool
Contact mitsu directly for repair and parts or those Facebook aircon services kind also can do?
stupidog
the newer daikin sucks. installed 7 years repaired 8 times.
each time repair cots about 220 to 540.
last time daikin better (before Y2000) it lasted 17 years before kaput.
tot daikin is reliable so i bought and installed back daikin in 2016,
till now already repaired 8 times. 5 times fan coil unit issues, 3 times compressor issues. all had to change parts.
now considering which brand is better
