monitor no signal
justiceknight
just bought a new graphic card to replace my spoilt graphic card and this new problem came. My monitor isnt consistently receive signal, cpu is working fine (fans running has lights etc). I need to keep reseting my comp until it receive signal, stuff i have tried is using DVI/HDMI/VGA and all has the same problem so i dont think its the cables.
I might getting a new monitor to test it out but that will be my last resort, is there anything i can test before i get it?
jtjt00
Without information on your rig parts, hard to comment. Better for you to bring rig to Nigel at SLS, #02-32 for troubleshooting.
house_md
had that issue previously, changed ps, monitor, still the same. removed and reinsert ram, ok. after a few days, come back again. removed 1 piece ram, ok. after a few days come back again. concluded, it has something to do with the ram getting loose. reinsert ram, put desktop to horizontal position (from vertical position), not getting "no signal" issue from the past few weeks. could be caused by new graphics card fan too strong, slightly causing ram to get loosened. desktop used to be side by side with monitor, now desktop lying down with monitor on top of it, neater and no prob anymore.
justiceknight
heres my spec, i still think its probably my graphic card is faulty even though its new (less than1 month old). Gonna use my warranty tmr. Anyway i have tried different monitor and still have the problem
i5 2500k gigabyte z68xp ud3
kingston 4gb ddr3 x 2 pcs
asus gtx 560 ti TOP direct cu ii upgrade to nvidia 960
hitachi 500gb sata 3
lg 24x dvdrw
seasonic x560w
coolermaster elite 431 plus
coolermaster 12cm fan
coolermaster hyper 212 evo cpu cooler
acer 21.5 inch S221
tp link wn 822n high gain wireless N usb adaptor
delivery, assembly and os installation
logitech k120 / k200 kb is at
win 7
