Motorbike beat red light or traffic light broke down? What do you think?
coinman
At first everyone including me was about to turn right as the green go straight light turned red, so we expecting the right arrow to turn green but it did not so the 1st motorbike already cross the junction liao.. so consider beat red light?
Then the next round, go straight light turn red, everyone guai guai liao, dun dare to move until traffic light returns to "normal" and the turn arrow turned green as normal.
coinman
the videos proved otherwise leh
The right turn arrow never turn green after the go straight arrow turned red the first time. Only 2nd time, it worked as "normal".. now i dun know what is normal liao
Laguna123
If green arrow can still on later mean no issue with the traffic light?
enimen
Maybe need to turn 2 times green to red for straight then 1 time red to green for turn right
Skoda29
Some are on demand by pressing button for pedestrians.So there cld be no fix pattern for some cross intersections.
Spirax
Maybe bike did not touch the turn right road sensor after certain cut-off timing
Orphan
I kenna right turn signal never light up as expected before as well.
Suspect the pressure sensor on the ground a bit of issue, never detect got vehicle on top, so skipped the right turn signal.
